RT Dual Exhaust
Has anyone removed the first pre-muffler/cat and ran true dual exhaust? There is two pipes coming straight down to the ground just before the pre-muffler/cat. All you'd need is two 90's to aim the pipes backward on the :spyder2: and then the duals back. I might try it sometime, just afraid it maybe too loud ??
someone did remove the cat converter section and fab a 2 into 1 into a muzzy I think exhaust can...
I think he was running slightly lean he said even after adding fuel some areas of the fuel curve. not sure if the spyder fuel injectors can flow much more fuel then stock. but it runs cooler ..
i am sure he will pipe in when he sees the thread...
