Hi Guys n Gals... I have a 2012 RT 998. Im pretty sure my cruise control worked fine last time I used it [last year] .. so today when I tried it [doing around 60mph] as I pressed set, the green set light flashed on and went off again and it didn't set. It did this every time I tried to set it. Turned cruise on and off but same result. If I held the button in the resume position then it would set a constant speed.. but to set another speed I had to turn the cruise on and off again otherwise it just resumed at the previous speed... any ideas? Have cleaned the switch with contact cleaner etc all looks well.
