RT Changing Brake Pads!
Sarge707
Changing 2012 RT rear tire at 16,000 miles and noticed the Brake Pads Need replacing. I know its a 9mm allen to get the pads off but the round disk (Parking Brake) is in front of one of the bolts- Do You remove it or work around it?
Make sure your not changing them too early! They are not like car brake pads.
Bob
Thanks for this video. I am getting a squeal from mine on a 2014 RT. Each time I have the bike serviced I ask them to check the brakes and they say they are fine. I now have a little over 17k and I getting worried. I just got in a hitch, so this will be a great time to check them.
Thanks again.
1 mm seems awful small for a brake pad but my rotor is fine (very smooth) and I take it they don't have a wear in thing that makes then start to chirp like a car.
Thanks Bob! After further review- comparing the New Pad with what I Have left it appears I have about 65% left on the inner pad and about 55% on the outer pad. This after 4 Years and 16,000 Miles (I had 2 Spyders those 4 years which kept the mileage down somewhat)
I am going to clean and lubricate the posts and paint some Brake Quiet with a tiny brush on the back of each pad and check again in another 4-5 thousand miles.
When I think about it my 09 GS was traded in with 33,000 miles and the pads were in Good shape - I don't expect the RT Pads to last as long?
I have 24K on my rear pads now. Mine is a SM5 and I downshift a lot.
I will be replacing them very soon.
Bob
Well, I checked my rear pads and they are fine. How does the front pads seem to wear in comparison to the rear pads? At 17k miles, the rear look very well.
I got 47,000 miles on my first set of front pads and I just checked them yesterday and they are still good with 41,000 on this set. My rear pads had 27,000 on them when I changed them last week.
A little tip for keeping the adjustment plates forward is to Put a crusty old sponge between the plates and the cover-Cut a slit on the bottom so it wraps around the bolt.
I did this on my 09GS and put them on the RT today because I Loosen the adjustment bolts 2 1/2 Complete 360 degree turns to work the belt of while moving the wheel backwards. I take measurement before and after like the manual does. I then tighten the same amount and take the measurements again. I just would rather do this sitting in a chair than laying on the ground trying to get the shock bolt Off AND On.
Which ever method you use this will help hold the axle forward.
