RT-622 grounding harness.
funon3
I have seen several threads saying to be sure to get the grounding harness for the trailer to avoid blowing out the trailer connector. A few months ago I purchased a new left over 2013 622 with the 4-square connector. Can I assume that the connector would be the grounding connector on the 2013 trailer or do I still have to be concerned about the problem? Also, is there an easy way to check the connector to see if it is the proper one? Any help would be appreciated. :bowdown:
If your BRP hitch is a new one with the 4-square connector, you should be fine pulling a new trailer.
YRMV
