RS-S running warm, or is it normal?
griffontamer
Hi all!
Went on a lovely ryde on this lovely Washington day. Just a nice short ride around town. The temp outside was around 50 degrees, plus or minus a couple.
I noticed that the RS-S coolant gauge was at 5 bars, which is a notable amount above "middle". Is that normal? The F3 never went above middle even at above 100 degrees outside so this seems a little odd to me.
Coolant level looks fine BTW, and the bike runs smoothly with plenty of power.
Has Two Brothers exhaust, if that changes anything; other than that I believe it is stock.
Thanks all!
Julia
My own experience
My 2012 RS-S usually runs 4-5 bars on the temp gauge unless it is 40 or below. I have never had any heat issues with my machine, so I am assuming that it is normal.
Just sayin'............
Normal....
Unless you are maintaining a constant speed on the open road. Around town slow traffic it will run 5 bars open road/freeway will drop to 3 or 4 bars...:thumbup:
Keep eye on it! My ST also stayed at 5 for about 25k miles then 1 day, few errands then spiked from 5 to 7 bars that put me in limp mode high engine temp & was later found to be hose clamp came loose (crimp on type)
attachment.php
Covered by warranty but still left me stuck. :banghead: After the fix it has been staying at 5bars:bowdown: only 500miles or so tested now.
