RS iPhone ram mount
Spyder ri
Here's an IPhone 4 ram mount I made for my 2012 RS. I wanted something removable and easy to use. I used a short arm mount and utilized the existing vent holes in the dash, drilling just one 1/8" hole to line up the top screw. I used two ss fender washers in back to add stability to the mount. Here are a few instal photos below. Tell me what you think!
Thats pretty cool WTG ! What did you use for the actual phone holder and how secure is the phone in it?
I'm using the same holder (bigger size) for the ZOOM and never had a problem. Just remove the phone at the first signs of rain.
I purchased a Buybits mount kit through Amazon that had the holder and wiring kit that works very well. You might eat to look at it.
That's a nicely executed modification. Should give secure mounting with easy access. For what it's worth, and I'm not suggesting you do this my I touch survived a trip through the washer. Not a recommended cleaning method:yikes::yikes:
I forgot to remove my iPhone when it started to rain :banghead:.. It is now in apple heaven:roflblack:
IPhone Mount
I used this mount - It is designed for the Otterbox Commuter Case on the Iphone 4.
It is very secure. http://www.ebay.com/itm/SlipGrip-RAM-HOL-4-IPhone-4-Using-OtterBox-Commuter-C-/400191446903
I also ran a 12v power cord up from the trunk outlet and will
secure it on the little metal tab that rests on the rubber shroud (under the handlebars)
Then I can just pop it out and plug it in. I'll post more photos when I get that part wrapped up
and weatherproofed (since the cord will always be there)
Thanks.
