RS Heat Management?
Huked
I was just checking to see if what everyone thought. I am looking to get some heat management. I just am not sure if I need it all?
This looks like it will do what I need. I'm not sure if part #2 is needed or not, if I get this?
http://spyderpops.com/the-air-management-system-2008-2012-gs-rs-rss-only/
This is part #2 Is it in addition to, or an alternative to part #1
http://spyderpops.com/the-missing-heat-shield-gs-rs-rss-spyders-only/
This part is to keep the engine cool. Is it something I should just get, or wait to see if I see any high temps?
http://spyderpops.com/gs-rs-missing-air-dam/
Replace the plastic coolant reservoir. The original will eventually crack and leak. Make sure you purchase the updated version with new part number.
Put on all 3. Number 2 was the most important as far as I was concerned. That bare exhaust pipe a couple inches from my ankle. Not good. Also for #2 it is very important that surface be cleaned and prepped properly. You don't want it to fall off.
Agree...
:agree: I installed the three you listed and helped a lot. I also drilled large holes in the bottom splash guards...:thumbup:
What year is your RS? I had a 2012 RS SE. I tried all those spyderpop products and they maybe reduced the heat by 3% (if that). I was considering purchasing the 2014 RS panels for my 2012 RS when I decided to trade my RS for an F3. The newer panels have heat reducing vents and are interchangeable.
Thanks everyone for your help.
1.) It looks like I will be getting all three it can't hurt.
2.) I will be taking off my unneeded panels.
3.) I will be keeping on eye on my Y gaskets, as I have just 5000 miles.
4.) My Spyder is a 2011. I will see how the rest works out before looking to other solutions.
I dunno whut y'all are talkin' 'bout, heat? I have a 2011 RS S with 32000 miles and I have no complaints about heat. MOF, I just gave away a Spyderpops heat management kit. didn't need it, didn't want it.
