First time Spyder owner and I just picked up an 08 RS, been out driving it around getting use to the handling. I noticed when going around corners its handles fine but long sweeping turns it gets a little touchy, when into the turn if I let off on the throttle just a little it wants to head for the side of the road, little more throttle it wants to dive into the turn. I was wondering if the suspension is setup wrong or there may be an alignment problem with the front end. I also noticed that the outside tread on one front tire is wearing even though tire pressures are within specs.
Maybe this is how they handle, don't know, haven't had another Spyder to compare against but it sure seems touchy especially going through the twisties.
Does anyone know what the front alignment specs are? Toe-in? Caster/Camber? I would like to check this if possible.
