RS alignment
docdoru
Silver Dream is schedule today for her first ever alignment done in 5 years...:coffee::shocked: ;)
:shocked: Are you sure that you want to "mess with success"? :shocked:
Good luck; let us know how the shop does... :thumbup:
If it ain't broke don't fix it
I hope it needed to be aligned. My dealer really screwed things up on my first alignment.
Good luck
Hope you are having this done due to some problem like tire ware steering problems etc. If not you will see no change (unless done wrong) at all or develop some new issue. Good luck..!:thumbup:
The only problem Doc has with his tires; is that they're never spinning fast enough! :thumbup:
Doc,
Did you ever find a narrower tire with the proper overall diameter? Maybe then, you could even do some streamlining to the fenders... ;)
I had my 2009 GS aligned and I couldn't believe how much easier it steered..I was fighting it and I wasn't even aware that I was....One side was toed out 1" and the other side 1 1/2"...tires worn out at app 5-6,000 miles...
...alignment turn out "within manufacturer specifications". I'm sure that SpyderDream was ryding with care over 191,000 miles :thumbup:
VERY careful, driven within the speed limits, miles.
Sent from my DROID RAZR using Tapatalk 2
