It's a long thread but may be worth it.....
I am interested in the mounting plate you are talking about. Since every shop near me do not have the correct adapter pieces to make the front rims fit on a dynamic balancer. One shop did it by mounting the rim backwards and putting pieces of cardboard in between to protect the paint. I did not like that. I was thinking of getting a custom plate made, but getting a one off part made gets pricey.
So I ask where did you get the plate you bought? How much? Do you have pictures you could share with us?
Thanks.
The following is information from 2011, when I worked on a vibration issue with my '09 GS:
They are emails between myself and Doug Wolverton of Hunter Engineering.
The parts I purchased are listed and not cheap. However, when I put new tires on, I,ve got what's needed to do the job!
Bill
Re: Hunter.com: Contact Us Information Request (Sales)
Bill, Sorry for the delay but once I get it set aside, it's hard to reel it back in with my schedule. The cost of the truck cone adapter kit would be difficult for you to justify at $802.00. Since you only need one part of it to use as a backing plate, you could use item # 46-562-2, which is the spacer component and it would cost you $298.00 plus UPS. The low taper cone is really very common on many balancers but if you wanted one of them also, it is $61.10. If interested, let me know and I can have our local service rep order one or both in for you.
Regards,
Doug W.
On Aug 21, 2011, at 5:55 PM,
[email protected] wrote:
Doug,
What would it cost me to purchase the following: low-taper cone#192-51-2, wheel spacer # 46-562-2( is this what we used as the backing plate?),
pressure ring#223-68-1
I'm thinking this might be the smart thing to do, then there's no question about the shop having the needed parts! It would then come down to using, proper procedures and the technician's level of expertise.
I posted your comments.
Thanks,
Bill
On 08/21/11, Douglas Woolverton<[email protected]> wrote:Bill, Feel free to post the following on your CanAm Spyder forum. I should have taken a couple pictures of the cone & adapter setup we used!
Additional information that may be beneficial to others seeking a vibration-free ride with the use of Hunter's GSP9700 Road Force Balancer:
Hunter has a web site to locate shops that have 9700s (
www.gsp9700.com) whereby you can enter a zip code and search around that area. You will not be able to know if the shop has sent technicians to Hunter's advanced "Rolling Smooth" training and you will not know if they have the adapters needed to mount and center the Spyder wheels on the unit. On the other hand, using the necessary adapters and procedure below isn't really advanced skill level.
Adapters utilized: #20-1929-1, Medium Duty Truck cone kit (see page 9 of Hunter Accessory Brochure) was needed as we used half of this two piece kit to establish a backing plate area on the balancer's hub that would accommodate the Spyder's small flat wheel surface. Without this, it would likely be a crap shoot to properly mount it with any other adapter pieces. #192-51-2, Smallest low taper cone (see page 11 of Hunter Accessory Brochure) was then used from the outside to center the wheel. With this "outside cone" set up it is also necessary to use the standard accessory #223-68-1, Pressure Ring with the wing nut (see page 6 of Hunter Accessory Brochure).
Procedure used:
1) Quick Check balancer calibration
2) Perform Centering Check on first assembly to insure the adapter set up was accurate and repeatable
3) Used SmartWeight mode, standard on all late model GSP9700s & older ones that have been updated
4) Reduced SmartWeight balance tolerances with a simple ccw turn of the GSPs knob
5) Insured that all tire pressures were consistent throughout processes (we used 20psi)
6) If tire to wheel matching is needed, best to use the "Measure Bare Rim" mode on the 9700 as the outer flange of the Spyder wheel is not suitable for an accurate measurement
7) Used tape weights and two plane "Spoke" mode to locate outer plane weights behind wheel spokes-out of sight
The vibration sensitivity of the Spyder isn't known (many car companies publish their maximum road force variation limits) but we were able to get one down to three pounds and the other down to seven pounds and this is solved my vibrations along with a good SmartWeight balance. Consequently, if you can get the roadforce variation into single digits you're likely going to also experience my success.
On Aug 20, 2011, at 11:41 PM,
Thanks
bill
On 08/20/11, Douglas Woolverton<[email protected]> wrote:Bill, Glad to help and glad to hear we smoothed it out! I'll drop you another note sometime with some details of what accessories & settings we used.
Doug
On Aug 20, 2011, at 10:32 PM,
Doug,
I was just logging on to email to post the following:
[h=2]Good News!![/h]
Originally Posted by
bill pitman
Background: I had a post in June relating to: "Check your ball joints!" Even tho the ball joints have play, I wasn't convinced that that was the main cause of my "front-end" vibration issue. As I stated in previous posts, I started to research wheel balancing and vibration control.
Hunter Engineering Co. , builds wheel balancer/vibration control systems(GSP9700), tire changers and 4-wheel alignment machines. I had emailed a representative and after several days I DID get a response!
Doug Woolverton, Northeast Division Manager of Hunter Engineering offered to meet with me in Lansdale,Pa. Hunter has a training facility there with various pieces of equipment (wheel balancer/vibration control machine, tire changers, alignment rack...).
So today, Doug, Gretchen and myself spent 2 1/2 hrs working on the wheels/tires of our Spyder. I had taken the wheels off the Spyder and spent Sunday night in Quakertown. The Hunter GSP9700 system has the ability to not only balance the wheel/tire assembly ,but to simulate a road test,using their "RoadForce" technology software. "RoadForce" allows you to not only balance the wheel/tire ,but to match the wheel/tire to help control/see the "spring-force" associated with the assembly. Hunter's website has great written info and videos which explain the concept.
It's been raining all day,so haven't done any road tests yet. I'll post good news, I hope. If not the quest will continue!
I wanted folks to know there are people and companies out there that will help work out problems. Sometimes it takes time ,but eventually things do get worked out.
Bill Pitman
8/20/11
Finally, after some delays(rain,bad back), I was able to get the wheels back on the Spyder.
The left wheel/tire had been "Roadforce" tested and then the tire rotated on the rim to match the machine recommendation. No weights were needed and the final "Road Force Measurement(spring force)" was 7lbs.
The right wheel/tire was "rotated and matched" and 1oz of weight added behind one of the 3 spokes & 1/4oz at back edge of rim. Spring Force was a very good 3 lbs.
RESULTS: Handlebar and console "vibration" is gone. There is no more vibration in the 58-67mph area, like I had previously. No issues up to 85mph.
Bill
Doug, I again want to thank you for your help in resolving our problem. Hope all is well and if I can do anything for you, let me know.
Visit Spyderlovers.com and look for replies.
Bill & Gretchen Pitman """""
5-18-14, Hope this answer some poeple's questions,
Bill
