Magdave
For those with fly by wire throttles it states in the manual that the ETC will make a high pitched sound for 40 min after shut down. And it does it drove crazy when I first brought it home unplugged everything in the garage and was checking the garage door opener and wiggled the garage door and it stopped. Thought for sure it was the door opener
pps: Now I know better. So the riddle is if you turn the key on the ETC makes no noise. Why then does it have to whine for 40 min after shutdown shouldn't 5 or 10 minutes be sufficient ? Seems like it is causing an un necessary battery drain to me.
One other thing what is it with the headlight system? I adjusted mine last night ( another fail from the dealer set up low beams went 15 ft in front of the Spyder) and now have decent low beams but the sharp cut off from the shutter prevents signs from being seen until you are very close. Wouldn't it have been better to use a dual bulb system?
