bayoumanPIBE
I made a video on how I raise the top case on my 2021 F3 Limited. I do not know if this method works for all F3 Limiteds.
During my own research, I found out many others also want to know how to raise the top cases on the F3 Limited. I finally figured it out and want to share in case this can help anyone else…this is my first how-to video, so let’s keep the video / audio criticisms to a minimum.
I needed to raise the top case in order to remove it when not in use replacing it with a rear fairing / fender. I recently received my rear fender but have not completed the top case removal process due to discovering a few things NOT mentioned in the owner’s manual which prevents easy removal...such as an extra wire going from the inside the top case through the bike frame, etc..
Ryde on…
Ryde on…
