BLUEKNIGHT911
Sadly Passed Oct 2024 - RIP
I definitely would not go wider than OEM. I bought new tires earlier this year to a Fredetein or however it is spelled, by several members here, and suggestions were to get the wider version. So I did. Tires aren't bad, maybe a little squirelly feeing, but the big problem is, with the wider tire, even though it doesn't hit the fender or extend outside the fender, it throws water up above the fender and ends up on you legs and shoes. I rode all the way from Michigan to South Dakota and back in rain, and sometimes heavy rain, and did not get wet with rain suit on. Once I got the wider tire, rain has found its way into my boots and half way up my knees, so I would strongly suggest to stay away from anything wider than the OEM.
I believe the tire you are referring to is the VREDESTEIN Quatrac 5 ….. and what you saying makes little to no sense based on the " physical " difference between those two sizes …… 10mm is about 3/8in. wider ….. and you say that tire is now throwing a hugh amount of water, compared to what you had been using...… I haven't heard anyone ( here ) who has made this size switch make this complaint...… why do you think that might be..... Mike
