Removing Passenger Grab Bars
Slagiatt
Obviously, this is a non-mechanic posting this.
Can you remove the F3 passenger grab bars by just removing those visible screws? And, if so, is there anything else that might mysteriously pop out or fall to the ground when you do? (I do so hate surprises.)
The reason I'm asking is that I believe I'll be able to mount saddlebags on those short "posts" that hold the grab bars on, but I have to temporarily remove them first.
So, will this be as simple as it seems, or will the back tire fall off :roflblack: or some other part that doesn't seem obviously related, get misalligned in the process) as I'm losening the screws?
:dontknow:
YOU CAN SEE HERE
Go to PROCALIBER.COM ....2015 can-am F-3 and look at the fiche'.......it will show you the parts involved and how they connect.....Mike :thumbup:.....I should have mentioned this .....if you sign in ( IT'S FREE ) you will get dis-counted prices.....:2excited:
As I see it..!!
the two outter (M8x30) ones and there is a tab going under the seat by the forward bolt with one more (M4x10). That should do it...:thumbup: this according to the parts catalog. Maybe someone has a shop manual...
