Removing bottom oil pan plate
rhoule1
I'm in the process of doing the 600 mile oil change and I can't figure out how to remove the bottom oil pan plate. The manual gives no explanation.
Can anyone help.
Roger
Can anyone help.
Roger
I believe there are 3 fasteners---2 on the main frame that can be seen by looking at the center spine below the engine. The is 1 behind the lower panel just below the oil tank. You have to remove the top splashguard fasteners to get to it. It will take some wrangling, but it will come out after removing the the 3 fasteners.
Good luck C-YA RL
