Rear wheel bearings...
sinkhole
Does anyone know if the rear wheel bearings can be pushed out from the back side, or do you need an internal bearing puller?
When I did my GS I Tapped two of them out from behind with a socket and extension just a bit smaller than the bearing-Piece of cake!
The larger one I had the dealer take off because I didn,t have the tool to remove the cir clip?? He then put the new tire and All three bearing in for me for $25.
Thanks Sarge. Looking at the drawing, it looked as if they could be pressed out from behind. Just wanted to be sure before I dug into the project. I'm at 25k and need to replace the tire, so I figured it was a good time to replace the bearings while I had everything apart.
