Rear Turn Signal Lamps
FYI
For those who use the AMBER Bulb for the rear turn signals, be aware that BRP is out of stock
AND has no idea when (if ever) they will be restocked.
If you use those type bulbs, suggest you keep the following link handy, just in case.
https://www.amazon.com/gp/product/B01I2V6YS0/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Be safe out there!
AJ
Not sure what model Spyders you're referring to but on the OEM rear turn bulbs (on my F3LTD) the pins on the bulbs are 120 degrees apart whereas the 1156 pins are 180 degrees apart if I'm not mistaken. 1156 definitely will not work on my F3Ltd.
RT - edited post to specify
