rear tire
Questions
I have a 2010 rt-s with 11,200 miles and the rear tire is shot. If I replace the stock tire with an automotive tire will there be any warranty issues or other problems I may encounter? I see others have switched to khumo or proxes 4.
Tires of the correct size are somewhat limited in selection. Be sure to get an excellent rain tire if you go this direction (there are some out there).
There should be no warranty issues. Tire wear and traction, (cold & hot, wet & dry) may change for the better or worse depending on which tire you choose.
