Now that is funny :2thumbs::roflblack::clap::roflblack: got me rolling in the aisles.
Anyway does that T1R have better traction? /Ken
The only tire I can compare it to is the stock tire. I believe the dry traction is better on the T1R. I gauge this by cornering stiction as opposed to burnout traction. The T1R seems to spin easier than the stock tire, but I added some HP and low end torque about the same time I did the tire change. It may be more power to the rear wheel and not less traction causing the added spin.
Plus, a worn tire will actually give you better dry traction than a new tire because with less tread you are actually transitioning to a slick. So why would the new T1R corner better but spin easier?
Could also be that the tread on the T1R (and I'm pretty sure every other alternative tire) is 4 ply whereas the stock tire is just 2 ply tread. In cornering it is very possible that the 2 ply tire distorts with the lateral stress, losing footprint. The 4 ply tire is much less subject to lateral stress and should maintain a more uniform footprint while cornering.
I can say for sure that wet traction is better. I did not get as good wet traction with the new stock tire as I do with the T1R.
I think just about everyone has been happier with their aftermarket tire than with the stock tire regardless of brand or model. Not to say that some won't give you better service than others, and certainly price varies.
My #1 concern was wet traction as I had hydroplaned with the stock tire. Of course I was pushing it because I wanted to see where the break point was. But the purpose of an aftermarket tire (for me) was to improve wet traction without losing any dry traction.
While most (if not all) aftermarket tires will give you improved dry traction over the stock tire, (some maybe more than the T1R), not all will improve or even match the wet traction of the stock tire (which is relatively good).
So it boils down to your priorities as to which tire will work best for you.
