Rear Tire size on an RS-S
Fly boy
I found tons of threads on the rear tires, there is rediculous amounts of info, and repeat of info. I want SPECIFIC info i.e. people need to say what they are putting what on. There are tons of differences between an RT and a 2009 RS SM5.
I know the stocker is a 225/55/15 but what size's CAN I possibly run that is different? :ani29:
I have a 215/60R15 Michelin HydroEdge on my RT. Will put one one my wife's GS, if she ever rides it enough to need a new tire...
No nanny issues, no slips or slides (yet), and the speedometer & odometer are both more accurate.
As long as your overall rolling circumferences are close enough; you can have all sorts of fun with those tire size calculators playing with your options.
Of course; changing all 3 tires at once to the same "size" gives you way more options. :thumbup:
Or even mount all 3 speed sensors on one wheel so as to mislead Nanny a bit... :shocked:
nojoke I'm not joking nearly as much as you think... The speed differential from different tire sizes gives Nanny fits. I've seen posts from several riders who just mounted all three on one wheel to keep her quiet...
Not that I have any idea of how to pull this little stunt off though! :opps:
CORRECT TIRE SIZE
225/55-15 ?..NOT.....OEM IS 225/50-15...at least that's what came on my Spyder ........Mike
No? You probably came up with the idea (or designed it). Your innocent guise doesn't fool me for a nanosecond!!:D
:roflblack:
:roflblack: I actually AM that stupid! :roflblack: Just ask my Missus about the time I got my arm caught under the engine in my XCR440... :opps: That was a VERY long afternoon in the driveway! ;)
TIRE SIZEING
You're right, the stock tire is a 225/50-15. That's why some are getting away with a 205/55-15, thought a 215/55/15 would be a better match.
Ron I agree with you. If my Kumho ever wears out I will go with the 215/55-15 size it's just a hair larger in circumference than OEM........Mike
