frank3
RT-S PE#0180
Used the procedure posted here to remove the tire/wheel from my RT. After the new tire was re-installed, I took the RT for a test ride and noticed a VERY harsh ride. On closer inspection, I found the rear suspension airbag pressure was above 60PSI. Not to go into too many details, but I found the rear height sensor bracket bent downward, causing the bike to over inflate the rear in order to achieve the bikes desired ride height. The bent sensor bracket was caused when lifting the rear of the bike with the shock absorber disconnected. The force of the rear spring forced the rear swing arms down, pulling the sensor and attached bracket down. I don't want to amend someone else's procedure, but folks need to be sure to disconnect the link arm on the sensor PRIOR to disconnecting the rear shock to prevent this from happening. I was able to bend the bracket back into its correct position and the ride returned to normal with the rear pressure at 35-37 PSI. I think I was lucky that I didn't break the link arm or do serious damage to the height sensor. I think the procedure might have been written for the RS or a model where there wasn't a ride height sensor involved.
