Rear speakers
joekeys
I have a 15 RT. I don't get any sound from the rear speaker. Is their a reason? I understand it has 4 speakers.
Look at the preferences screen of the multifunction gauge in your owner's manual for the audio settings and you will see how to adjust the fade so the rear speaker volume can be adjusted. They will not play as loud as the front speakers.
:agree: Hit "Mode", until you see the Preferences Screen.
Use your "Down" button, to scroll down to your Audio Settings
Use your "Right" button, to move over to the center of the display, where you can pick the feature that you want to tinker with.
Find the Fader, and highlight it, then hit the "Right" button again.
(Now you'll be all the way over into the right of the display...)
Use your "Up", and "Down" buttons, to move the setting to where you want it.
As an example: I normally have mine set at about +1 to the rear... :thumbup:
I tried this and moved it from center and all the way to rear and nothing from rear. The higher the number on the R setting the lower the volume on the front. Do you need a passenger on the back seat to get it to work?
You've got something (The rear speaker wiring), disconnected from the radio. nojoke
Your bike might still be under warranty; let the dealer take a peek at it.
Good Luck! :thumbup:
No passneger needed
You may not have rear speakers if you have a base RT.
