Rear shock replacement 2018 - any tips?
stillwater
Does anyone have any tips for replacing the rear shock on my 2018 RTL? We ride 2 up a lot and I got Elias for the front and rear. I got the fronts on but had to take off the frunk to her to the top bolts. I am hoping the rear will not be as much hassle.
3/8” extension for your ratcheting wrench, with a wobble feature. Last one I did took a couple of hours. Easy, but lots of steps!
You will have to remove the side panels. But you can get the top bolt from the side of the bike.
The lower one can be done on the ground with the bike jacked up a bit.
Hey thanks I got it done! The YouTube video was helpful. I did not have to take the rear trunk loose but needed to use 1/4 extension on top nut to avoid the assembly on the right side.
