_..stiffler..
Hey guys. Finless has a great video on YouTube for an RT model that is exactly the same as what I'm going to show you pretty much. But I thought I'd show pics on how to do this just to help others.
So first thing I did was drive up on ramps for the front (no need to do this. But it gets it higher off the ground.)
Then I placed the jack under the center frame bar at the rear just in front of the catalytic converter.
I jacked the machine up just till the rear was off the ground.
I then removed the bottom shock bolt only (15mm socket on each side)
Then you can play with the jack to get it just right so you can pull out the bolt. Or if you're strong enough. I just lifted the rear suspension with one hand and pulled the bolt out when it was easy to do.
After the bolt is out jack up the machine so the wheel is off the ground a couple inches.
Now take the belt guard off. Just 2 torx screws. Not sure on size. But easy.
Now grab the top part of the belt just in front of the sprocket and roll the belt reverse and pull outwards on it a bit at a time (do not get your fingers caught in the sprocket it will hurt like a b@$&h.) Keep doing this until the belt comes off.
Now on the other side remove the traction control sensor. It's just behind the caliper and has a silver hex head screw on it. There is also shims when it comes off. Don't lose those.
Now remove the rear caliper or you will scratch your rim. It's 2 bolts 16mm in size and easy this hoses get at.
Now remove the axle. 36mm socket on each side. The right side while facing this Honeoye rear of the bike is the one to come off. And you pull the axle out through the left.
You can adjust the jack so the axle comes out easy. Or again lift with one hand and pull with the other.
Be careful. There is a black plate on the right that will fall and scratch your frame if not careful. Get another person to hold that plate if needed.
After axle is removed. Pull the tire and rim out and you're done.
The dealer will need all the parts on the rim to balance properly. So don't take anything off.
I just ran a couple zip ties through the rim so I don't lose the bushings etc.
Attached are pics.
Hope this helps.
Stiff
Oh and while it's apart. Do not turn power on and don't hit the brakes.
Sent on Note 5 in Taptalk
Attached are pics.
Hope this helps.
Stiff
