Rear Led Strip for the Trunk
bluestratos
Looking for some help, I have the LED brake/running light that mounts up high on the rear trunk but when I use my luggage rack it obscures it. I am looking for the LED strip that mounts between the trunk lid and the trunk. Something nice and bright that I will hook up to my brake light pulser to match the upper one.
I Looked through the threads and the venders but cannot find it so any help is appreciated.
Thanks,
Randy
TricLED... :thumbup:
attachment.php
Go to Spyderpops website WWW.spyderpops.com and look at the new system that he has for the RT series it is very bright , has FOUR lights that act as Running, Brake & Turn Signals all for $95.00 shipped to you for free. This is the system that is on my 2015 RTL.
Cruzr Joe
Joe,
Hard to tell from pics on his site... When turn signals come on does that half just flash - and in same red, or are there amber LEDs for the turn signals?
And is this kit just the just horizontal strips or does it have the vertical strips running from tails to bottom - and if so, does that have to be put in with kit or is it separate/optional?
Joe,
It is the two vertical and two horizontal set, when used as a turn signal the entire right or left half flashes, when you hit the brakes the entire set gets brighter. It is all plug and play as a set. All red, no amber.
Cruzr Joe
Frunk brake and running light!
Don't know if this is what you're looking for! SPY-HMT OR SPY- HMT- INT IF YOU WANT THE TURN SIGNAL ALSO! Note= the spy-hmt-int will give you a fast flash on the 13 R t model!
This are very nice and brite! Have them on my bike! Lot of sponsors here have them available! Custom Dynamics, value accessoriesand, others as well! You'll need to buy the spacers for your luggage rack! Hope this works!
I ordered the trick light set and installed yesterday. I linked them up to my upper running/break light which I had set up with a strobe when the brake is applied. Now if I have something on my luggage rack the two new LED strips flash as well.
