Rear end pop
kentuckyguy
I have noticed a pop in the rear end on my 09 RS.. This occures only on take off an it pops 1 time.. I have checked the rear bake an all is ok.. I have even came to a complete stop without use the brakes to see if it still pops an it does.. I took it to the dealer this morning an they got it to do it alot.. They was dumb founded by it.. They took it back an check the belt tension an it was ok.. They called Can Am tech support an they told them to tear the rear end apart.. So they did.. Tech told me the cush drive looked ok an the only thing he could see was there was a couple bolts that wasnt tight enough inside the hub.. They retightened an locktite the bolts an the bike still does it.. He called Can Am back an they are sending everything new for the rear end (wheel, sproket, bearings and axel..
Tech told me to go ahead an ride it that it was safe an when all the parts came in they would give me a call to bring it back in... Anyone else ever have any issues like this?? If so what was the outcome?? Do you think it is safe to ride?? Thanks
Also look for a missing tooth on the belt, damaged sprocket, or for a bad drive sprocket/drive shaft. There are possibilities related to the clutch, too. Sometimes the results of problems elsewhere in the driveline, are heard or felt seeming to come from the rear wheel. BRP will help your dealer get to the root of it. Sounds like your dealer is committed to finding the cause and curing it.
:dontknow:
I hope its not the same.
My 08 was making a similar noise, I thought it was coming from the rear bearings, It ended up that the front sprocket and the shaft wore out,
Its in the shop over two weeks now, And I'm in no hurry to get it back,
$$$$:( I'll just ride my two wheeler, I'm flexible.
