Hello everyone, I am in the process of changing the rear tire and unfortunately put the parking brake on when the caliper was off the rotor, the pads are now tight and I cant seem to get the caliper to release. I have removed the pads and used a u-clamp to try and compress the caliper. I tried to release some pressure thru the bleed screw, but no luck getting it to compress. Any suggestions??
Thank you in advance for your time.
Daniel
Daniel
