rear axel bearings
SethO
Of course no dealer has them in stock, anyone used any from a parts store that were the same or better??
NO ONE IN THE MIDWEST has a sprocket side bearing, got to put over $100 to get one because of saturday.
Carlos if you are reading this it would be nice if there was a way to drop ship parts to the homes of people who own and ride these bikes, I am 75 miles away from the closest Spyder dealer, and they are low grade.
I would gladly ride up or drive up to CANADA to get it right from the factory and buy it from you.
thanks, I got a narrower one in with a spacer,(less weight more speed) its great having a machinest as a roommate, like a dumbass I did not search bearings on here, I am going to end up paying 90 for one I had overnighted to brainerd MN and go get it done.
thanks to everyone who PM'ed me
just got to get a front alignment and I should be good for a while.
those are the singles as well, I had to get the one out of the sprocket, a 30mm id 55mm OD by 23mm which is a double row.
seth0 - totally good call having a machinist as a roommate, nice!
How many miles do you have on that rear bearing?
Also, did it go before, or after the suggested mileage?
Cheers and good luck!
