I have a 2017 F3T. While the side cover is off so that I can adjust the drive belt and install the DocH damper, I noticed coarse and fine sand under the air bag. I have read that this can cause the bottom of the air bag to wear and eventually fail. I also know that there is an after market boot that can be added to address the problem.
My question is: has anyone tried applying a bead of silicone under the air bag to keep debree out? My thought on procedure:
1. Empty air from air bag.
2. Jack up rear of Spyder.
3. Clean between bottom of air bag and frame.
4. Apply bead of silicone.
5. Fill air bag to max specification.
6. Lower Spyder.
7. Let silicone dry.
8. Adjust air pressure before mounting Spyder.
Regards,
Don
6. Lower Spyder.
Regards,
Don
