I should have My Spyder all ready for this riding season. Today I replace the tires with car tires. The rear I installed a General Altimax RT43 215-60/R15 and on the front a pair of Federal AZ01 165-55/R15. I also installed set of 3 Centrimatic Balancers. While doing this I bleed the brakes. I checked the brake pads, the front was fine but I will be replacing the rear in three or four thousand miles.
Changing the rear tire was much easier than I thought would be. It did not change my belt alignment or tension at all. The hardest thing was to get the tire to take air. I finely got a strap around it and twisted a long screw driver in the strap and got it to take air. I was worried about the brake bleeding but it was real simple. I had forgot that I had purchase a one way valve tube bleeder for my Goldwing’s back several years ago. I used it and that really makes bleeding brakes easy. Better than a Mity-Vac not much chance of getting any air in the system. My Spyder is a 2015 with about 18,000 miles on it and the brake fluid was black. I have one of Doc’s belt vibration damper and I have done laser alignment so I don’t know what else I could do to it make it any better. I suppose I could change out the sway bar to one of Bajaron. That I may think about but I ride alone and only weigh 150 lbs. so I don’t know if I would notice much different.
