waow! I've never notice that one! Thanks for posting!Did I read wrong in the Manual that I can NOT turn off the radio,
I have been looking for a off switch but can't find on; The manual say just to mute it.
Does this also mute the Zumo
Thanks Guys for the information. Never in my lifetime have I ever seen a Radio without an off switch.....
:hun: If you turn the Ignition Switch to OFF, the Radio WILL go off - completely!! If you hit the volume button twice, it WILL shut off the speakers - completely!! So the radio isn't truly turned off, altho for all reasonably foreseeable intents & purposes, it is! Effectively, it's just like every one of those other devices you have around the place that you leave with a 'standy-by' glowing - it's sorta vaguely technically OFF; but in reality, it's got some power & is still ready to work at a moments notice!
But seriously, does it really matter if the radio still has power going to it?!? If you can't hear it at all, surely that's the desired outcome? :shocked:
You can have the radio on to listen to if you want; you can have the GPS on to listen to if you want; you can have either or both on to listen to or not if you want..... ISN'T THAT THE WHOLE POINT??
So what if the radio doesn't 'switch off' like your old valve based set did! It's not costing you any more gas or making you ryde slower; it's not making the engine wear out quicker or run hotter; it gives you noise as and when you want it, and it goes silent as and when you tell it to.
:thumbuproblem solvered, move on; ryde more, worry less!
When you start the bike the radio needs to be unmuted until the first audio comes from your GPS. Then you can mute the radio. Otherwise, the GPS audio will be muted. At least that's the way it is on my 2014 RTS.I agree with what you are saying, I was under the impression that to hear the GPS the Radio would have to be on, Now I am finding out that it does not.
Again Thank will have to check that outWhen you start the bike the radio needs to be unmuted until the first audio comes from your GPS. Then you can mute the radio. Otherwise, the GPS audio will be muted. At least that's the way it is on my 2014 RTS.
On a related question:
I'm still figuring out all of the "options" on the integrated audio system on my RT Limited (including CB).
It is beginning to appear that to get a decent volume from the radio and CB in my headset, the speakers must be ON too.
Seems like it would be dumb to design it that way so there might be something I have overlooked.
I get everything set up so I can hear everything and then go to the option to turn the speakers OFF......and the volume seems to go WAY down in the headset for everything but the GPS; it blasts through no problem.
