No mode button? :gaah: So you can not follow start procedure & the radio is least of your problem??:dontknow: Sounds like fickle switch & should get dealer to fix before it gets worse! Go ahead & check others for good measure.Hello...turned my 2014 RTS on today....radio is stuck in aux ...eco select button work good ....mode button does nothing.....radio volume up and down or left or right .....nothing....any help would b grt
Sent from my XT1031 using Tapatalk
Bike runs grtOops my bad..mode switch works good...its the set switch not working... Or the four radio control buttons
Hello...turned my 2014 RTS on today....radio is stuck in aux ...eco/ mode select button work good ....set button does nothing.....radio volume up and down or left or right .....nothing....any help would b grt
My bad....mode works goodNo mode button? :gaah: So you can not follow start procedure & the radio is least of your problem??:dontknow: Sounds like fickle switch & should get dealer to fix before it gets worse! Go ahead & check others for good measure.
They don't work on any modeDo the set and direction buttons work in other screens? For example the trip meter screen or settings screen. Or do they not work only on the audio screen?
Yep...got extra years on bikeLooks like a new LH handlebar switch assembly. I hope you are still under warranty it will be about $400 plus labour.
Do u know where the radio is located on 2014 rtsLooks like a new LH handlebar switch assembly. I hope you are still under warranty it will be about $400 plus labour.
Do u know where the radio is located 2014rtsPerfect. :thumbup:
Sent from my XT1031 using Tapatalk[/QUOTE
From the symptoms you describe it's not a radio problem. But to answer your question. It is in the right rear. Near the antenna.
