Radio install tips.
Dar
Just ordered the factory am/fm radio system for my RT. Any tips for a smooth install? Are there directions that come with this?
Just where does this install on the spyder?
I'm afraid that most of us with RTs already have the radio, and most of those without it didn't add one. BRP accessories do come with instructions. If your audio system doesn't, you can contact your dealer to have him download and provide you with some. As I recall, the radio sits under the rear bodywork, which means the rear trunk will have to come off, but I can't say with certainty. Much of the remaining bodywork will need to be removed to run the wiring and install the speakers. Doing the rear speakers will entail even more panel removal. This is not quick and simple, but the BRP instructions are usually very good. You will need help, human or mechanical, to handle the rear trunk. Keep track of which screws go where...they are not all the same size. Labeled ziploc bags work well for this.
radio install
just did xm, cb,wire harnes,and phone set up. yes all side comes off, then trunk needs to be lefted up some for wiring to route took me over 10 hours to do.yes each have print how to do. just take your time.. Better yet do all of it at once and be done with it .if you need to buy all of it e-mail and get you a good price for all of it............:bowdown:
