R35 Hard bags
challman
Hi. I have posted other places about my Hard saddle bags and my lost key. Have resolved my issue doing this
I purchased a new lockset with 2 barrels and 4 keys. I purchased these here.
http://www.twistedthrottle.com/trade/productview/910
The part number is Givi z227
I took the bags with Spyder attached to my local lock smith who had already tried to pick the lock with no success. He bored out the barrel. (basicly it looked like he put the drill in at the top of the key opening and drilled down then side to sided it till the lock would turn with a screw driver.
Once this was done we had the cases off and open.. We disassembled the lock and latch mechanism. (this was unnecessary) I t turns out that there are just 2 screws that hold the plastic piece that latches the bags shut. When you pull this out. Remove the E clip, pull out the old lock set. Then insert the new sleeve that comes with the lock-set. (the new tumbler is smaller than the original and the sleeve makes it fit.
slide the new tumbler in, replace the plastic cam and e clip.
re install the latching mechanism.
YOU are Good to go.
Anyway the most important piece of info here is that the Givi PN Z227 Works just fine in the Can-Am R35 bags
Ride ON!
Cole
YOU are Good to go.
Ride ON!
Cole
Great news...yes, replacing the barrel is really the only way to go!
