I don't quite understand what the rear suspension system is actually supposed to do, based on what I've read here. The indicator on the dash shows adjustment from "hard" to 'soft", but comments here seem to indicate it adjusts to maintain the correct ride height based on rider/passenger loading.
Although I never hear the compressor running the system appears to be working. With me on the seat, in gear, engine running the "soft" setting reads about 30 PSI when checked with a gauge on the valve under the seat. After adjusting to "hard", the pressure has risen to 50+ PSI, so obviously the compressor is working as it should.
The load on the suspension is the same in both cases since it's me on the seat both times, so what is that change in pressure doing if the ride height remains constant? Need some education here. 2013 RT-S.
Thanks,
Bob
Thanks,
Bob
