Question Lamont
canam9
Lamont,
I would like to replace the front shocks on the RT-S.
Can you tell me what shocks you went with and maybe why you choose them.
Also did you replace the rear aswell? If so what is your thinking on that combo?
I know they will not be cheap, but on something like this,what is:roflblack: What ball park will I be looking at?
Thank you for your time.:ani29:
I have the 1-way
1-WAY: The basic unit offers adjustable preload (used to compensate for riding solo or two-up with or without baggage) of the spring and adjustable rebound damping. The spring is supplied in the proper rate for the rider's weight.
Right now I am running the 250lb spring and it's working fine if you compress the spring to 8.5" I have a set of 300lb springs here that I'll be putting on as soon as my finger heals up a little more. This will give a little better ride as I won't need to compress a 10" spring to 8.5". It's still way better than stock. nojoke
