Question for Lamonster???????
BumbleBee
RT-S PE#0174
Did you test ryde on both the RT and RT-S?
How would you compare the two based on ryde, comfort, and available options?
Thank-you in advance for any information you can provide!!
Thank-you!!
I am having a hard decision to make between the RT and RT-S now :dontknow:
I am not sure which one to go with!!
Any input?????
From what I have seen, you can get most of the options for the RT if you wish. This includes audio, foglights, accent lights, and so forth. Same seat and controls, so that part of comfort should be the same. Biggest difference seems to be the electronically adjustable rear suspension. The ability to control the firmness of the rear suspension from a button on the dash is something that may be desireable.
Thank-you!!
Hi "frau hummel":helpsmilie:
for me also !!
(from today also in austria we can order the RT..)
maybe lamont can you give us your 4000 dollar statement ..what would you do ?
if i order the basic-model and use this 4k for "costumize" and buy a audiosystem / rear shock .. all this .. do you think its better invested ??
(think the cable-loom on all models will be the same ..)
chris
chris
for me also !!
chris
chris
Through the years I have bought the cheaper version of things and did what I needed to do to make it like the more expensive version. Sometimes it works out and sometimes it doesn't. You're going to have a real hard time doing any better than the stock sound system on the RT and I don't see how you would do a on the fly air bag system like BRP has and make it turn out half as good. In this case I would just buy the loaded RT and be done with it. I don't think you'll be disappointed at with what you get even though it cost you a few bucks.
+1 on what Lamont said.I did hear from someone at BRP that the wiring harness is the same on all R models and most acc. will be stocked at dealers and most will be plug and play.
:agree:
