Question about Sena 20S
If it's like the SMH-10 I push the phone button once on the rear of the unit my phone makes a double beep and then I say "call house" or someone else on my contact list.
If you plug sena into your computer and look into the updates, you can also program 3 numbers into the speed dial. Might be a real good idea to look into the voice activated command list too.
Just sayin'...........
my phone does not use speed dial at all. SO, I'm not sure what to do on the speed dial part. unless the number are stored in the sena unit and then dialed through the phone.
I have looked in the manual and it is not very clear on this.
Bill C.
That one. :) Three of them, at max.
To use them, either double press the phone button and rotate the dial to choose "redial" or one of the three speed dials, then press the phone button to call,
or double tap the helmet or say "Hello Sena" in standby mode or press the Ambient Mode button (the one below the mounting plate) to activate Voice Recognition mode and say "speed dial 1" to "... 3" (or "redial" for that matter, which makes the phone redial the last number it has dialed).
I call through my GPS which is paired with my Sena 20s
I have my iPhone 4S phone paired with my GPS (Garmin that comes with the 2015 RT-LTD) and my GPS paired with my Sena 20s. I do not have the Sena or BRP Bluetooth dongle installed. I make the call through the Phone app on the GPS and am able to listen and speak through my Sena 20s. This works great for me.
Rob
