pulling out speedo/tach
obiwanbill
Manuel says to stick screwdriver in the two slots above on the dash, then pull loostened unit out, like to replace headlamps...trying to install 2 individual turn signal indicators that I bought on Ebay last week.
The black plastic edge bezel comes off, looks like it attaches to the clear plastic instrument casing...but the case doesn't budge. What am I doing wrong? 2008 se5:helpsmilie:
Once you place a small screwdriver into one of the slots and push down, use your finger tips to hold it out a little. Then, push the screwdriver into the other slot. The top part is now loose. Tilt it forward and you may have to lift a little because of the lip at the bottom. Just be careful of the big plug connection. Some members have bent pins when the plug came undone.
The black edge bezel and the clear plastic come out as one piece.
