motoguzziman
I bought a small pull behind two wheel trailer to pull behind my 2020RT. The trailer has a torsion (ie rubber) suspension and has 4.80 x8 tires. When I was replacing the lights I noticed a couple of stickers on the inside of the box which showed that the hitch weight should be 20-30 lbs and that the tire pressure should be 20 PSI. This sounds like a pretty low tire pressure but then again we will only have about 100 lbs max in the trailer. The soft tires would help smooth out the bouncing which is not bad. (Suspension is rated at 250#).
If you have a similar trailer, what are you thoughts on the tire pressure. What tire pressure do you run?
Thanks
Thanks
