Mad Matt
RT-S PE#0256 SyderLovers Sponsor
We have been getting alot of phone calls and emails regarding our new handlebar and center console set up for the Spyder. I finally have the production bars in my hands so I put together this photo with the dimensions so everyone will know exactly what these bars are. These bars were designed specifically for the Spyder and have the correct knurling in the center. They are .095 DOM tubing, not the cheaper tubing with a seam or thinner wall. They are beautifully powder coated gloss black. Some people are concerned that the stock cables will not reach with the taller bars. The test bars I currently have mounted on my Spyder are 8~9 inches tall (per the diagram below) and the stock cables still work! The pic of my Spyder shows the center console with the yellow spyder web inlay. You can also see there are 3 built in mount points located in the ideal locations for GPS, Intercom, MP3, and even a cup holder or whatever you want. Mine currently has the Garmin Zumo 550 on the right, the J&M Intercom and CB on the left and a cup holder in the center position. We provide a universal GPS mount that has the Garmin Zumo hole pattern already designed in. Also remember, with these bars, you can rotate them in the handlebar clamp for significant fore and aft adjustment capability, something you can not do with the stock handlebar cover. This setup also works even if you already have the BRP riser installed.
Mad Matt
Mad Matt
