Just want to say how pleased I am with the guys over at SPYDERPOPS.
I ordered cat shields block and frunk seal on Monday and got here on Wednesday.
Seal fit fine and easy to do.
Block also easy however fitment needs fine tuning but that just me.
Cat shields also easy with play by play instructions. Took more time in put the machine in the air then to install.
Let me say this as well, in the instructions the writer states and I quote
" The Process is easy as you just have to pop the clip down and pull out the connecting pin." It really is that easy! And a must, I tried to go around this and it is no go.
The writer goes on to state and this I found to be most useful quote
" There may be a plastic zip tie securing the clip and it will have to be cut loose first. I have noticed the zip tie on the newer RT's and would recommend putting them your even if it didn't have them from the factory. I think it was good for them to put this info out as I could see that if conditions were right it would be possible for the clip to come off.
Brake Clip! My 2010 did not come with the zip ties. BRP must now think its a good idea to put on the " newer" models.
I as I would think this set up is the same for all Spyder SE models RS/GS RT I would consider putting on the zip ties. I put them on mine.
Thanks SPYDERPOPS. :ani29:
I
I
