proper way to use krikit
aka1004
i just bought a krikit part number 91132 and i tried it but i was only getting reading of 100 . may be i am not doing it right. what is the proper way to used this thing? also, do you do it with spyder sitting on the ground or jacked up?
thank you in advance.
The last post on this thread (Link Below in Blue) has instructions for using the Krikit II. If yours has the lip on one side you cannot center it on the belt so I am not sure the readings will be accurate.
A sign of the times!
If you have the one with the lip bring it back. Napa gave me my $$ back even without the receipt!!:firstplace:
Mine has the lip and I just put it on the edge of the belt. I get very consistant readings on the edge of the belt. Since the reading in and of it'self is pretty much meaningless, consistancy is all that really matters.
How to use:
Have your belt adjusted to new spec by dealer
Check it with kriket (check on the edge with lip or in center with lip ground off)
remember this reading (whatever it is)
