problems with Ipod integration cable
dfox
Anybody having problems with the ipod integration cable not enabling the ipod to be recognized through the audio controls? When I first plugged it in it worked fine the second time all I get on the audio screen is the aux id.
ipod
Ya i had that same problem..i think its a connection problem.cuz i will be ryding down the road and it stop and starts so i filled up my truck will stuff that i need and i just lay it on that stuff.but im going to fix it.which i think will work .....which is buying a i pod holder an mounting it to the wall so that when im ryding it wont jump around in the back...
Chuck
I have seen a few posts on this and I know others have had problems. I am on my 2nd cable and it doesn't work all of the time. This is for a 2011 that has the extra 'black box' in the cable assembly.
It can be the cable, the connection, or just a need to reboot the iPod. Sometimes they are particular about needing to be turned on before or after you start the Spyder. Sorry, I don't remember which they prefer. BTW, if you have a newer version iPod and use a converter cable, the Apple cable is more reliable than some aftermarket cables.
I am not having any problems with mine on a 2011 RT-S SM5. I have the black box in the cable (older version of BRP radio).
I leave it on all the time and never turn it off unless I know it will be parked for weeks.
If you turn off wifi, BT, set screen to full low dim, etc, the battery last days!
When I power up the spyder, I can hear the iPod (4th gen) make it's usually beep sounds that it is connected and charging (like when you connect it to your PC).
This is how I mounted mine. They heavy duty Velcro provides pretty good vibration damping. The black box is also mounted so it does not flap around.
Bob
