So, I am using plasti dip on my Rally to see if I want to bling it up a bit. If I don't like it on a certain panel, I can just peel it off.
So, today I was using some CLEAR Plasti Dip and it started roughing up in spots, that looked like some lint or dust had gotten into it. Believe me, it wasn't dust or lint. It was pure Plasti Dip in little hardened grain like spots. Then on one piece (the tail light cover) it actually went milk white. The whole panel was milk white! So, I peeled off my hood and tail light cover and started over again with a new can. Since no stores in the area had CLEAR Plasti Dip, I ordered it on line and received two cans. So, the second can started doing the exact same thing. I was using clear as a base because someone had told me to use it to keep from staining the plastic parts with the color. I was planning to use the clear on the silver parts of the Rally and then go over it with black before using the Metalizer. So, the black PD is working fine with no glitches. The metalizer is fantastic. Once it dries real well, I plan to use the Glossifier over the PD'd parts. Once I get it back together, if I don't like it I can peel it and do something else. If I like it, I can eventually do it in permanent paint.
I do not know if I did something wrong with the Clear Plasti Dip, or if I got two cans from a bad lot. All I know is that I dont' think I will use it again.
If you have any experience with this stuff and know what caused it to act up, let me know.
I'll post some photos once I get it back together.. I am also using pin striping.
