For the last few weeks when riding to work in 40 degrees or less outside, I've noticed my power steering isn't working as it normally does. It seems to just not activate which to be frank is quite scary, sometimes it is intermittent, and sometimes not at all. This situation quite dangerously obviously because you need it the most when turning and that is when I can't rely on it.
I called my local dealer that I bought it from and was told to try to keep it on a battery tender as the power steering is the first item to get power cut to it when battery is low.
Anyone else encounter this issue? It seems 100% directly related to the temperature as when I ride in the morning in the cold I run into it, then when it is warmer in afternoon it doesn't have the issue anymore.
Also I noticed twice this summer, two days in a row when it was 90 degrees or higher here, that my check engine light was on and wouldn't turn off (in the afternoon at the heat of the day), then the next morning back to normal.
Are these extreme behaviors common for spyders, or am I just an unlucky one?
