ShawnFZR
There was a bulletin (Roadster #2012-6 - Spyder RT - Possible Water Infiltration in Radio Module) that was released at the end of last month. However, I'm finding that most of our customer's don't seem to know about this until it pulls up under a VIN inquiry when entering our service department for services.
Possible water infiltration into the radio module may lead to various issues, including excessive battery drain during short none use periods. A very limited number of units may already have sustained damage from water intrusion. If the Spyder RT has an XM Radio installed, bulletin #2012-7 includes a satellite radio update kit to be performed at the same time as the above mentioned radio bulletin.
The bulletin applies to all 2011 - 2012 Spyder RT A&C, LTD & S models and all RT’s that have dealer installed BRP Radio and/or XM Kits. The inspection and prevention procedure takes about 30 minutes to perform, plus an additional 30 minutes if the unit has an XM radio installed.
Make an appointment with me at Pro Caliber Motorsports and I'll get this taken care of for you!
