bluestratos
I use a high power fan to help keep cool when I hit stops lights or stop and go traffic. I often pour water over my self when it is really not out to help cool while moving. I got to thinking, why could I not just inject water into the fan stream and improve the cooling effect.
I mounted a small water pump down low inside the wasted space on the left side behind the snap off access cover and connected it to a camel back water bag in my frunk. I then plumbed this up and into the fan with a mister nozzle so it blows a very fine mist and voila, works perfectly. I have a small valve in line that I can reach to turn the amount of water up or down to control how much water I use. It is drawing about 10 to 15 oz. per hour so my 3 liter tank lasts a good three hours.
I wired it up to 2 shallow rocker switches up under the dash overhang, the first one turns on the fan and if the fan is running I can then run the pump an option but not the other way around so I don't waste water.
I put in ice to see if it improves the cooling effect and yes, but not a great deal more than the ambient temp water, I think it warms up in the air stream due to the atomization being so fine.
