PLEASE HELP WITH COMMUNICATION SYSTEM
oldfarmerboy
I have a :spyder2: 2012 RTS and I'm wanting to install a communication system. What I would like to be able to do is talk to my passenger, listen to my radio or Ipod on a head set. I would like to do it with a SENA. Can you help me with what all I need to buy and some tec help on how to install it all thanks.;)
We have the Sena SMH-10 comm units, and a Sena SM-10 Bluetooth "hub". MotorcycleDave on here (SL sponsor) has all the stuff you need to get you started.
Using the SM-10 hub, I am able to hook my Spyders stereo into that, so it transmits wirelessly to the comm units. I bought my SM-10 from Sena, and had to build my own cable to hook it to the bike, however, Dave may have that part worked out now. If not, and you are shy about building your own cables, you can buy the same setup from BRP. It will just cost more, but you will have the cables / connectors already provided, so it's just plug and play.
I am not a techy expert, but do use the Sena SMH10 as communicators. The unit does not have to be wired into the bike but works from helmet to helmet. We use ours for bike to bike communication.
The units install right into most any helmet. You pull the lining, place the earphones into the sculpted out places, install the sending units on the helmet shell with a turn of a screw. Your then pretty much set to go.
Motorcycle Dave--a sponser on the site sells the Sena units.
+1 on the SENA units. SMH-10's here use them for bike to bike and stream music from the smartphones(wife likes her own tunes). +1 on Motorcycle Dave:thumbup:
CALL ME 209-887-3283
Hi Have here... give me a call I can and will help.
Thanks everyone for the great words..
Dave
