Hello Spyder Lovers
I need some help, I watched the you tube video on taking on the rear tire on my 2012 Can AM Spyder Rt, I removed the position sensor, the shock bolt, brake calipers, belt and removed the axle bolt, but tire will not move. Plus the previous owner put on hitch, I was able to remove the nuts to take off the hitch, but the last two bolts will not slide out, because one bolt hits the rear sprocket and the other the rotor. I figured no issue once I removed the axle bolt I would able to move the tire and then bolts would slide out, no such luck, about ready to reassemble and take it the dealer. What did I miss?
Any help is greatly appreciated.
Henry K
Henry K
